Johnson outboard mounting.
GTP091
The transom is solid. I poked around a few of the holes and there was no rot. I'll get more on that when I drill the bolt holes out. Thanks for the replies. I think I have enough info to get to work.
GTP091
I got the motor mounted on solid. Used biggest bolts I could fit through the factory sized holes on the stern brackets. Looks great finally on there. I also mounted up the motor controls. I need to replace the solenoid but the rest of the electrical tests good. Neutral safety switch and all grounds 12 volt test good. Now working on the steering linkage to the motor. The boat has a push pull steering system. Not cables/pulley like was common on this era of motor. I need to fab something up but make it so the linkage will move with the motor when put up for trailering. I can't seem to find a good closeup of this anywhere on my motor type. YouTube and Google didn't show much. The only video with this setup I found doesn't get in close enough. Can anyone posts, send me a picture or diagram of this setup? I was thinking a heim joint setup might work but open to ideas or the correct setup if I can get a picture.
F_R
No Title
This generic picture shows the basic idea of how it is done. you need a transom support tube kit or a splash well support kit. My opinion of the systems is not good. It will work but not well. The motor was made for rope & pulley steering.
It depends on your ambition.-----I have modified a newer tilt tube with some brackets.--------Then mounted that as high up as possible on the inside of transom.---------Attached the steering with the drag link.
F_R
It appears to be disconnected from the transom bracket in the picture. In the final set-up, will it full-tilt without interference? Will it fully steer hardover to hardover?
GTP091
Thank you all for your replies. 82rude the pictures are awesome. Gives me something to work from. ill be gathering the parts fo the linkage and will post my results. Its getting close to storing this project for the winter but hoping I can get it as far along as I can. Cheers.
82rude
​Yes it worked perfectly in all respects.The boat in picture came with modern steering ,if it had of come with the old style I would of never messed with it as that was a reliable simple system.
