2004 Johnson 90hp 2 stroke outbouard, I have loosened and removed all the necessary bolts, and also shifted it into reverse and undid the lever up on the right hand side of the engine which shifts the motor into reverse neutral etc. The unit will drop about 1-1.5 inches down and will not go anymore! Did i miss something with unhooking something whether it be the driveshaft or the gear rod? is there a disconnect somewhere? A few friends advised to take a sledge hammer and a 2x4 and hit it free because it may be rusted up top but i am just too nervous of ruining my engine doing that, i tried with a hammer and a 2x4 doing light - moderate taps and it doesn't want to come out. Please help and be a little bit descriptive if you can as this is my first DIY servicing. Thank you for your help
