Johnson Lower Unit will not come off! HELP
deroya
2004 Johnson 90hp 2 stroke outbouard, I have loosened and removed all the necessary bolts, and also shifted it into reverse and undid the lever up on the right hand side of the engine which shifts the motor into reverse neutral etc. The unit will drop about 1-1.5 inches down and will not go anymore! Did i miss something with unhooking something whether it be the driveshaft or the gear rod? is there a disconnect somewhere? A few friends advised to take a sledge hammer and a 2x4 and hit it free because it may be rusted up top but i am just too nervous of ruining my engine doing that, i tried with a hammer and a 2x4 doing light - moderate taps and it doesn't want to come out. Please help and be a little bit descriptive if you can as this is my first DIY servicing. Thank you for your help
If it drops 1-1/2 inches, the driveshaft is free. On those motors, you probably have a clevis pin under the starboard carb, which needs to be pulled. Then the shift linkage under the carb will need to slide left to free the shift rod.
Don't use the BFH, or you will really break something expensive....
deroya
Thank you, i was able to figure this out earlier. Got the job finished now the boat won't go into neutral, prop constantly spins when i shifted to reverse the plastic lever which pushes it back and forth snapped off. To the shop it went.....
