Johnson LD-10S
magnum7269
Where can one find some information and parts for this engine, like plugs, impeller, prop, etc... I've searched around on google and the forums here and can't really find anything about this johnson. Thanks for the help.
F_R
Honorary Supreme Mariner
Re: Johnson LD-10S
That is a 1965. The parts you mentioned are easy to find...right here at iboats for one. EXCEPT the prop. They are extremely hard to find. I'll send you a PM on that.
magnum7269
Re: Johnson LD-10S
Thanks for the reply, I took the lower unit off to check the impeller and some of the parts fell off from up near the engine before I could see where they went exactly. I'm a bit of a noob with this engine, so if anyone could tell me if i've got this in the right order I would appreciate it. :eek:
Parts Loose...
Hopefully The Right Order...
And if someone could give me a spark plug brand and number to replace the old ones (not sure if the ones in it are even for it) that would be great, Thanks again :)
magnum7269
Re: Johnson LD-10S 5HP
Took this little engine out to try it and to see if it was worth investing much into, ran pretty good only thing i saw was what looks to be a small amount of oil coming out from under the flywheel. Figure maybe an oil seal may be leaking or something. any tips on checking/changing this would be greatly appreciated. Also since the johnson parts catalog only seems to go back to 68, would most of the parts like the oil seal etc. match from the LD-13B model? Thanks again.
