C-Daddy 10
Thread starter- Joined
- Jun 7, 2018
- 5
Looking for some help here. Trying to sort out an engine that was running fine last year until late summer. Symptoms: boat hard starts, takes almost full throttle to fire. It runs horribly rich after that, and will start to die at anything under 2500 rpms. Someone tried to remedy the issue before me (it's my grandpa's boat). I've tried resetting the fuel screw's on the carbs anywhere from 1.5 to 4 turns out. No noticeable change in running. I've changed plugs, have great spark and new fuel. The person who looked at it before me put a new fuel pump on it. It looks like he also tried to adjust the timing.
I have no idea what the correct timing for this engine is and am having trouble finding it online. I have pulled and inspected carbs. They look new. I have pulled both reed valve assembly's. Both look OK, although I can see a little light coming through 1 of the 4 reeds in one assembly, and the same on the other. It's hardly noticeable. I did notice that when I pulled the air box off, there was gas in the box on the intake side of the carbs. Before I just replace the reeds, can someone tell me the correct timing on this engine so I can double check that? Also, if anyone has any other great ideas, I'm listening.
Thanks in advance for an help. The engine is a Johnson 50 outboard. I believe a 95 or 96.
