Re: Johnson-Evinrude Powerhead Swap?
jimmbo is right, there might be a slight difference, but both will fit into midsection. If you want to be sure to keep the 35 HP stick to the exhaust tube from the 35. You have to replace the base gasket and therefore have to get the tube off the powerhead. Be sure to tighten the small bolts properly and use a little locktite on threads.
