Johnson Evinrude 1980
djnicastro72
Hi all,
I have a 1980 35 hp Johnson Evinrude 2 stroke.
I have dual controls, one for throttle and one for gear.
Whenever I am going forward and putting it into full throttle the engine jumps into neutral and then back into forward. It continously does this while I am at full throttle. I can watch as the gear control pulls back on my control box.
Any ideas?
Crosbyman
shifting cable adjusted properly ??? is this a new issue ?
a new to you motor ? recent install ??
oldboat1
"As far as I know" means it needs to be checked. Always disconnect remote cables at the engine, and operate shift and throttle at the engine. Remember to rotate the prop slightly when shifting into gear. When satisfied the motor linkages are working properly, reinstall the cables to match the engine linkage locations -- adjust cables as needed with adjustment wheel.
Too late now.-----The clutch dog edges are like worn with repeated abuse.-----Time to take lower unit apart for inspection.----Price of new parts will shock a novice.
