Johnson cd-12 5.5 hp gear problem
Strat92
Flywheel turns when i pull the motor apart at the impeller, but does not turn when put together in any gear. Suggestions?? Thanx
aj1978
Re: Johnson cd-12 5.5 hp gear problem
Do you mean, that you turn the motor over by hand cranking, and the prop doesnt spin? Check to make sure your shear pin is good. Then I would look into the gearcase assembly, please give a lil more info and be detailed.
F_R
Honorary Supreme Mariner
Or are you saying you can't rotate the flywheel, but you can if you remove the lower unit? That is a siezed gearcase. You will have to look inside to see why it is siezed. Could be full of rust. Or could have a broken shock absorber---the short shaft below the water pump.
