Re: Johnson 90 will not go over 2200 rpm at wot in the water after complete overhaul
Post #34. Bottom line. I almost guarantee it. (Maybe).
Never saw a spark tester like that. Is that white bracket plastic? Might work ok on a surface gap plug, but a plug with a bent ground electrode? And resistor plugs? I don't know....
The spark tester in my pic is adjustable, the plug wire plugs on one side, the other side has a clip to ground, and the spark jumps across the gap that you set by turning the red knob. The actual spark plug is out of the picture (not used).
