hollywoodwayne
- Aug 27, 2008
- 58
this motor has got me stumped it will run great wot for about 60 seconds then bogs down.I've cleaned carbs,checked compression replaced fuel lines,new filter,new plugs,I think its a fuel issue because when i hit the choke when its starting to stumble it will help.it has the vro disconnected and plugged,gas is 50 to 1.This is a new motor to me so i have no history with it.its around a 89 or 90 year the id tags are gone.I've tried different fuel tanks different lengths of fuel hose.If i pump the fuel ball it helps but doesn't solve the problem.I know that an electric fuel pump is dangerous but I tried one in line in addition to the engines fuel pump(just as a help trying to diagnose the problem),and that also helps but it doesen't fix it.It acts like it has a air leak or a fuel restriction somewhere.It idles great and will run at half throttle if i slightly pump the ball Oh yes it doesen't have any thermostats in it yet.Is there a screen or anything in the vro pump tha could be restricting it or could it be something as simple as an adjustment to the carbs.well this is about all the 1 finger typing i can stand any help would be greatly appreciated
