I just purchased 1979 Johnson sea horse 9.9hp motor. I got the
motor started by removing 1 spark plug and putting in a small
amount of gas. Motor ran great with plenty of power and idles
down nicely. I drained and flushed original tank and refilled with
fresh gas and oil. I used 32:1 mix is this correct? Started
motor again and ran my boat around lake for about 20 min
with no problems. I stopped the motor several times and
it would restart on first pull. After letting sit for a couple
of hours I could not get it restarted. I put some carb
cleaner in tank started as I mentioned earlier and ran
at various power levels for about 15 min with no problems.
Let is sit for several hours and again would not start,
I made sure tank vent was open and squeezed bulb till
firm but just would not start. Any suggestions on what
my problem is?
my problem is?
