thatone123
Banned
Thread starter- Joined
- Mar 7, 2009
- 707
This is a late 60's model. I have totally cleaned the top half of the carb and it will only run the the choke 3/4 closed. I had a old spare 9.5 and took off the top half of that carb and the same thing, after I cleaned that one. I have put new points and condensers in this motor. It's not like I have not worked on these old war horses before, but am stumped on this one. Usually a carb cleaning clears up this kind of problem. It has a strong water leak the I don't want to put a new gasket in as I have had these before and they run that way it seems. The leak is under the cowling near the recoil started and comes out of what I believe is the exhaust manifold. That would not make the engine run lean, would it? Any other possibilities?
