Johnson 9.5 driveshaft stuck
meyer12
So far I have just been lurking and finding out lots of good info. But, now I have a problem and I can't find the answer so here goes.<br /><br />I received a 1964 Johnson 9.5 from a friend for a price to be determined after I got it running properly. He said it was overheating. I thought no problem I'll just change the impeller and away we go. So I took the lower end off and sure enough there was rubber everywhere.<br /> <br />Only problem is that the driveshaft did not come down with the lower unit. I have since removed the powerhead and can see where the shaft goes into the engine and have been soaking it in WD-40 for a week and putting wood blocks on the bottom of the engine while holding the driveshaft and hitting the wood with a hammer all to no avail.<br /> <br />If I ever do get the driveshaft out, the lower part of it has quite a bit of scoring on it where it goes into the lower end should I still use it?<br /> <br />Any help would be appreciated.<br /> <br />Tx
alcan
Re: Johnson 9.5 driveshaft stuck
Hi Meyer<br />You have a case of what I call sword in the stone syndrome. At this point there isn't much to loose. It is how ever worth a try. Be creative. I have welded things to the drive shaft in order to get a good hold. Clamped it in a vise and used hydrolic jacks to try and push the power head off. I've soaked them in everything I could think of (for a couple of years on one). I've tried the slide hammer routine. The last one I had was a 6hp evin. I ended up disesembleing the powerhead. Now just having the crank and drive shaft, I thought I would heat and beat. I never did get that sucker apart. Sorry to say that the odds are against you. But you still have to try. Every once in a while you'll get lucky.
meyer12
Thanks for the help. I am happy to say that I finally got it out. After a week of soaking with WD I clamped the driveshaft in a vice between 2 pieces of soft wood with the engine hanging down over a bushel basket full of rags. Then I put a piece of wood over the engine and hit it with a large hammer. 2 good wacks and that's all she wrote. Now to get it back together, so much for the quick impeller change.
alcan
Alright Meyer<br />I am glad to hear a success story.
Chinewalker
That should actually work well for you when it comes to the "price to be determined"....<br />- Scott
