Johnson 8hp 1985 how to tighten the throttle?
salmon44
Hello,
I do a lot of trolling for Salmon & Trout at low speeds however, anytime I let go of the throttle on my 1985 8hp, it will eventually stop. My queston is how to I tighten the throttle so it stays in place when I let go? I think it might be by popping the rubber end cap off the throttle and tightening a screw? Just looking for advice before I mess something up.
Vic.S
Re: Johnson 8hp 1985 how to tighten the throttle?
That clamp is only fitted to the sail versions 6SL and 8SRL but it may have been fitted to others later.
BETTER DIAGRAM
Its a pain, my 84 6hp sail version does not have the clamp!
In theory it would be possible to obtain and fit that clamp part number 394522
but I have made a fibre washer just thick enough to tighten the arm #39 in THIS DIAGRAM
It's a bodge but it works!
salmon44
Thanks for the responses guys, much appreciated. I may have to live with it the way it is, I would hate to mess it up.
