mbaker1351
Thread starter- Joined
- Apr 8, 2011
- 3
1990 88Spl., created a fuel leak(dry rotted line repaired) this is when I was asked to fix. Previously this leak caused a flash fire. Motor ran decent when I got to it, ran it to check for leaks. Found recirc. lines melted and inlet nipple on bottom carb melted. Replaced, all good. Superceded bowl was slightly different but all seemed good w/ clearance and float chamber. Started motor and ran flat at higher rpm's. Pulled plug wires and bottom cyl. dead. Sprayed fuel into carbs, and motor cleared up. Pulled carb back off and found nothing. Tried starting, wouldn't fire. Good spark and 115psi comp. on all 4 cyl. Checked fuel to pump, good, nothing coming out. Replaced fuel pump, still no fuel exiting fuel pump. Sprayed fuel directly into carbs and motor will fire.???? Am I not getting pulse pressure to operate fuel pump or please help w/ any other thoughts.
