Johnson 75 V4 serial number look up
tbaz
I believe I have a 1960 Johnson 75 V4 but I can locate the model number. The number on the welch plug is 2141067
I have not been able to find a cross reference to the model number. Anyone have a source to match to the model number and year to this serial number
It is an electric start manual shift model
Thanks
Tim
Daviet
Re: Johnson 75 V4 serial number look up
It used to be, a long time ago, that they produced a dealer catalog that cross referenced the serial number to a model number. You had to be a dealer to get one. Maybe check with your local dealer and see if anything is still around.
yorab
Ensign
Do you have the original transom brackets? If so, there should be a plate with the model number stamped onto it as in the pic.
tbaz
Thank you for the information. My plat was painted over but after I new where to look I was able to get it cleaned off. Thank you
It is a 1960 model v412s
Thank you
