Johnson 70 hp
John Brady
I have a 1986-90 Johnson 70 on my Pontoon. I am curious about the charging system on it. Can any of you guys provide me a link so I can study it or can you tell me How many amps it is and what kind of system is it? Is it a permanent magnet alternator like on a harley or is it a feild would type of unit like a car alternator. Also does anyone make a higher output charging system for outboard engines? Any help would be greatly appreciated. Thanks in advance!
John..
tashasdaddy
Re: Johnson 70 hp
it creates electricity thru the flywheel and stator, the converted to DC current by the rectifier, to charge the battery. and most don't have much output until atleast 2500 rpms.
iwombat
Re: Johnson 70 hp
It's a magnetically induced current, just like in a harley (or BSA, or Triumph, or . . .).
John Brady
Re: Johnson 70 hp
I figured thats what it was. Do you know how many amps it makes?
iwombat
Re: Johnson 70 hp
I don't off-hand. But, you should specify a little more clearly what you're interested in so someone can chime in.
Amps AC off the alternator, or Amps DC off the rectifier/regulator.
I'm guessing you don't much care about the AC output (only really useful for testing the alternator) and want the highest DC output from the whole system you can muster. Or, at least you want know at what rate you're charging the battery so you can calculate potential drain.
John Brady
Re: Johnson 70 hp
Im wanting to know the maximum output that the battery would see. So yes the DC output current. I am just curious as to how much it CAN produce. I work for a starter and alternator company in tech support and was just curious...
tashasdaddy
Re: Johnson 70 hp
i thought you want to run circus lights and a music, on the pontoon.
John Brady
Re: Johnson 70 hp
yeah that IS the real reason.....Its an older boat with no permanent furnature on it so i'm wanting to make it look like a Tiki hut.....LOL
