Hello, I have a 1973 Johnson Stinger 65 hp ( 65ESL73R ) that hadn't been started in 20yrs. This summer I replaced all the seals in the lower unit. Along with a new impeller. rebuilt the fuel pump along with all new gas lines. Pulled and cleaned all 3 carbs. She started right up and seemed to run pretty well on muffs. Took it to the lake for a test run and when I put the throttle to it she came right up on plane like it used to do, but then it started cutting out. You could tell that one or two cylinders were cutting in and out. I could play with the throttle and it would kick in and haul a** for a minute or two, but then start bogging out again.
When I got it home I put the muffs on again and started it up, this time you could hear the cylinders kicking in and out just at idle. It was pretty obvious, so I know It wasn't doing that before on the muffs.
I checked for spark by pulling one plug at a time. No spark at all on the top cylinder, the middle was good and the bottom was weak. Then I did a compression test and only got 60lbs on all 3 cylinders. I know 60 isn't good at all, and it's hard to believe that all 3 are going to read exactly the same psi.. but they did.
I also find it kinda surprising that when all 3 cyl were firing, even with such low compression that it still had as much power as it always did.
I am at a loss as what to do now. I hate to throw more money into it trying to find out whats wrong in the ignition causing it not to fire in two cylinders.
The low compersion wouldn't cause it to misfire, would it?
I welcome any and all thoughts, ideas, suggestions and recommendations!
Thanks for reading!
Thanks for reading!
