Johnson 50hp 1996 won't switch off at key switch.
janul15
Hello all. I recently posted about a non starting outboard. Followed your advice, found a disconnected power cable, and a broken neutral switch. I also replaced the key switch. Now , I can start the engine, have it running for as long as I like, but removing the kill switch does not stop the engine. Turning the key to off also does not stop it running. What should I do?
tblshur
just so u know an automotive key switch will not work on a boat hope this helps
