Johnson 50 only running on one cyclinder
BOAT DOCTOR
I have a 98 johnson50 it only running on one cyclinder done went threw carbs twice all passages r clean and free of trash,reed valves ok and has fire on both cyclinders and compression was 130 both cyclinders what else can it be any ideas number 1 is the one giving me trouble
TampaNate77
Re: Johnson 50 only running on one cyclinder
nevermind.... just reread it and seen you said its getting fire
TampaNate77
It has to be something with the carb.... If you got spark, and compression. Has to be in the carb.
BOAT DOCTOR
checked carb a 3rd time found nothingin carb.srayed carb cleaner threw every passage and seen whered it came out at could timing play a part in that but not sure how to set.
