johnson 3hp, need help
brando25
I am having some trouble locating a model number on an old johnson 3 horse.
this motor has the low and highspeed carb adjustments, runs the j-4j sparkplugs and has the start proceedure and the gas/oil mix on the gas tank.
ive looked top to bottom for some kind of model no, but havent had any such luck. on the plug on the side is (bo4o617) any help would be appreciated.
tashasdaddy
Re: johnson 3hp, need help
post a picture of it.
you can up load to a free service like photobucket.com then you choose the pictures you want( clik the little box at the bottom left of the picture) scrool to the bottom of the page, clik generate html, it will take you to the next page, scroll down to thumb nails clik on that and copy, then insert it into your post.
also if you are planing on posting pictures, you can use the Blue post reply or the go advanced, manage attachments, there you can upload , directly from your computer. besure you pictures have been resized to fit the format.
