johnson 30 smokes and bogs down
kylelowry1
I have a 1995 johnson 30 tiller that has left me stumped. I was given them motor and told it idles but bogs under throttle. Tried it out and that's what it does. I cleaned the carb in an ultrasonic cleaner and installed a rebuild kit in it. I also put a fuel pump kit in it. Still does the same thing. There is 110psi in both cylinders. It smokes bad when idling and it seems like there is excessive fuel. Plugs are wet and pools below reeds in intake. To check the reed valves i removed the fuel pump line from the crank case and blew air into it. It is passing air through the reeds. Is myself blowing enough to seal them? I am at a loss with this motor. Any help would be great.
jasper60103
Regarding the "smokes bad when idling" problem.
Did you check your primer?
I had an experience with my primer being stuck open, and it smoked like crazy.
Good luck.
-jasper
fireman57
Are your floats set correctly? Pretty much level when turned upside down? Running 50:1 it will smoke a little when cold but should clear up when engine warms up. You might take the carbs off and shine a flashlight into the reeds and make sure there is not a screw or bolt from the cover that has found it's way in there. Has happened to me a few times and that is the symptoms I had when it happened.
kylelowry1
The float is good. It wants to idle, seems like its running okay, then will start popping and will stall.
