kylelowry1
Thread starter- Joined
- Aug 11, 2015
- 3
I have a 1995 johnson 30 tiller that has left me stumped. I was given them motor and told it idles but bogs under throttle. Tried it out and that's what it does. I cleaned the carb in an ultrasonic cleaner and installed a rebuild kit in it. I also put a fuel pump kit in it. Still does the same thing. There is 110psi in both cylinders. It smokes bad when idling and it seems like there is excessive fuel. Plugs are wet and pools below reeds in intake. To check the reed valves i removed the fuel pump line from the crank case and blew air into it. It is passing air through the reeds. Is myself blowing enough to seal them? I am at a loss with this motor. Any help would be great.
