Re: Johnson 25 throttle issue has me stumped (UPDATE 2....COIL-NO, POWER PACK-YE
Spark plug wires are brand new, if was the ground for the coil, then in my opinion the coil wouldn't work intermittantly, or it would be more obvious that that would be the problem. Somethings going on with this motor after it warms up and the problem has repeated itself about 20 times. So if a the ignition coil after warming up and getting hot had a small crack in it, it would expand due to the heat and then create problems like I'm having correct? this is what a friend has told me. Therefore the test I'm going to do tommorow is to see if the boat runs good then take it for a ride, my usual ride, and get it to the point of where it either bogs down or a cylinder stops working, then I will do the ignition coil test of swapping them and seeing if the problem follows a certain coil. I'll post my info tommorow, thanks for the help in the meantime.
