Johnson 25 hp powerhead interchange?
maineiac5586
Master Chief Petty Officer
Hi, I have a 2003 Johnson 25hp 2 stroke with a siezed powerhead. I have tried to unsieze the motor but it is not happening. I am now looking at replacement powerheads. Does anyone know if a powerhead from a 1993 25 hp will work on my motor? I looked up part numbers on boats .net and the crankcase part numbers are the same. I did notice that the crankshaft part numbers are different. I am wondering if the end of the crankshaft where the driveshaft from the lower unit goes is different. I am afraid to order a used powerhead for fear that it won't bolt up. Does anyone know if this is possible or was there a design change at some point that is going to leave me stranded. If anyone knows what years powerhead will interchange your help would be much appreciated. I really want to put this outboard together and not have to resort to stripping it down and selling it for parts. thanks. Below is a picture of my outboard.
jasper60103
Re: Johnson 25 hp powerhead interchange?
... I did notice that the crankshaft part numbers are different. I am wondering if the end of the crankshaft where the driveshaft from the lower unit goes is different. ...
No experience with this sort of thing, but what model number is your motor?
And which crankshaft part(s) are you referring to?
The Crankshaft Assy (P/N 0435492) appears to be the same from 1993-2005...
http://www.**********/parts/detail/brp/B-0435492.html
