johnson 235 block
tbirdkidd
does anyone know where I can buy a good used johnson 235hp outboard block. needs to fit 1984
emdsapmgr
Re: johnson 235 block
Are you looking for a regular 235 block or the special 235S block? The basic 160 cubic inch big bore blocks were made between 1980 and 1991. They started out as 235's then became the 175 in 1986. The 235S blocks are rare and are hard to find.
Faztbullet
There are a lot of the 2.6 175/235 blocks laying around as the sleeves where thin on these models. The 2.6 GT(S) is the "good block" with squared ports and scallop cut pistons from factory. If you need a ready to go block call MAR-FAB.
tbirdkidd
Is there a phone number for MAR-FAB
tbirdkidd
Just the basic big bore
Faztbullet
Marine Fabrication Inc.
2455 Smithville Hwy.
Sparta, TN 38583
1-800-476-1554 toll free
931-738-2815 local
931-738-2819 fax
