I have a 1994 Johnson 200 and #6 (bottom right) is heating up. I replaced the water pump and head gaskets and cleaned out the passages and blew them out. When we start the engine on the muffs and when warming up the three left cyl's go to 135-140 and the lower right will go to 175 while the middle goes to 128-130 and the top one barely goes to 120. This takes about 5 min if that .The pressure is strong out the pee hole. Thank You for any help
