Johnson 1995 70hp no spark
nikoweb1969
Good morning my johnson no sparo on the 3. CDI is ok. Stator Have 400ohm fron orange to orange-yellow word. and 0 ohm from brown to brown-yellow. Is correct? Thanks
Honorary Supreme Mariner
Charge the battery and have battery load tested.----Fact---If flywheel turns slow there will be no spark generated.
DVA cranking voltage is the only way to know for sure if you need an expensive part replaced. You can use a meter without one, but must be rated to handle it, and then add 30% to that highest number you get will bring you in the ballpark. should be right around 175-250v DVA or so depending. do the same for the sensor coil and primary output of power pack to each coil.
nikoweb1969
thanks, do I have to do the measurement with DVA only by turning the starter motor, or with the engine running?
nikoweb1969
however if I have an open circuit in the stator, I think there is definitely no voltage
these are cranking tests. might be hard to start without spark:)
Faztbullet
Insert two brad nail into connector and retest. Dont think your probes are getting deep enough to read
