Johnson 1981 V-4 90 no spark on #1
bonitasprings
Re: Johnson 1981 V-4 90 no spark on #1
I did replace it but it wouldn't start. Turns out the ignition wire got toasted so I ran a new wire w/fuse (25 amp...will change to 20 thanks) from switch to solenoid. Started right up...except for # 1. Some of the wires coming from under the flywheel looked and feel a little spongy. Blk/yell especially so I cut that wire and inspected it and then butt connected it. When I did that I got spark in #1...but only for a few minutes. disconnecting the stop circuit and starting the engine doesn't cause any changes though (also, same with the rectifier).
I tried to follow the instructions for checking the circuits from stator but when I do the needle on the meter doesn't move...same for the good side. Admitedly, I am electronically inept. Should the meter be set to ohms? (dah!) black test grounded and red to the prongs in the 2 and 4 prong plugs?
bktheking-is that a picture of a toasted stator?
Can a stator be bench tested?.....what could cause ONLY ONE CYLINDER (the SAME one) not to fire? even when you move PP and coils around? A stop circuit couldn't do that could it? It would shut down a side...not just one cylinder...right?
This boat starts right up. I especially like that push choke (primer?)...Would love to see how it is with all cylinders firing.
bktheking
I really don't think you should troubleshoot any more until that flywheel is pulled, it may be a visual that leads you to figure out what is going on. Make sense?
bonitasprings
Well...I couldn't resist. got some good instruction on resistance testing and tested the sensor coil resistance. It failed miserably. On the bad side (starboard) between A and B was fine (40)btween A and C there was no movement of the needle at all. On the good side between A and B reading was 80 and between A and C was 40. Project is at a standstill for now (I is Po...) Thanks for all your help. Will repost when starting back up work on it.
bktheking
It's like I thought, 1 of the sensor coils is gone in the timer base, out comes the wallet.
Glad you figured it out.
bonitasprings
Yup...160 bucks up the street at Marina Mike's. Feels good to at least have an answer tho. Thanks for all your help.
Life goes on
