So far:
Engine fires up when I spray fuel in carburettor (spray bottle>gas/oil mix).
I can run it in neutral and it will stay running on higher RPMs with out spraying in the fuel).
In lower RPMs engine shuts of unless I spray the fuel in the carb.
I'm thinking carburettor cleaning /rebuild is what i need to do, or any other suggestions?
Replaced all fuel line hoses,cleaned filters,tested fuel pump.
Ignition does not seems to be an issue (sparks under all RPMs and it will idle if spraying fuel in carburettor).
Other observations so far
-fuel pump seems to pump fuel fine
-water pump tested fine
-milky oil in lower unit
-two unidentified tiny 1/8" holes on lower unit (seem to be connected to water path?)
-compression high
-engine switch wont cut of engine(need wiring diags)
-some wires disconnected (need wiring diags)
Thank you for support.
u4david
-compression high
u4david
