Johnson 1968 40 HP rdsl-30c no idle
u4david
So far:
Engine fires up when I spray fuel in carburettor (spray bottle>gas/oil mix).
I can run it in neutral and it will stay running on higher RPMs with out spraying in the fuel).
In lower RPMs engine shuts of unless I spray the fuel in the carb.
I'm thinking carburettor cleaning /rebuild is what i need to do, or any other suggestions?
Replaced all fuel line hoses,cleaned filters,tested fuel pump.
Ignition does not seems to be an issue (sparks under all RPMs and it will idle if spraying fuel in carburettor).
Other observations so far
-fuel pump seems to pump fuel fine
-water pump tested fine
-milky oil in lower unit
-two unidentified tiny 1/8" holes on lower unit (seem to be connected to water path?)
-compression high
-engine switch wont cut of engine(need wiring diags)
-some wires disconnected (need wiring diags)
Thank you for support.
u4david
F_R
No Title
Of course you have tried adjusting the slow speed mixture needle, right? Otherwise, time to open up the carburetor and see what's plugged up. Here's your wiring diagram. Ignore the generator stuff if you don't have one. Drain holes in lower unit are normal and on purpose. Don't be fretting about them.
u4david
Thank you so much fro your post/reply.
I did not adjust the needle yet. Will check in to that.THX a lot for suggestion.
Do you have wiring schematics that covers the same engine as you posted above but with out the generator?
If my engine does not have generator does the battery gets recharged by other means (magneto)?
Can you direct me to a doc or write-up that covers replacing seals in lower unit (I have milky oil in lover unit)?
Thank you so much for taking your time to respond. Much appreciated.
Those motors only charge the battery with a belt driven generator.-------Check for spark on both leads.---Spark must jump a gap of 1/4" or better.---Sounds like it is running on one cylinder.
lindy46
If motor doesn't stop when you turn the switch off, check out the two black wires going to the "M" terminals on the ignition. Those are the kill wires. Follow them back as per diagram and make sure they are connected properly. No, your engine does not recharge the battery if you don't have a generator. You'll have to put a charger on the battery periodically. Seal kits are available here on Iboats. You'll have to drop the lower unit and take apart the gearcase to do the job. A little complicated for a newbie. You may just need to replace the crush washers on the drain and vent bolts. Were they in there when you drained the gearcase? Sometimes they fail to get replaced when the oil is changed.
u4david
Today I got the engine running ones more. I cleaned the carb on the engine and adjusting the slow speed needle and mechanical auto choke also fixed. Wow, this motor runs great, idles ok as well. I noticed that while in gear the RPMs get much higher than while in neutral. Is that some safety to keep the motor from accelerating without any load?
u4david
The wiring diagram is great. I will rewire and report back on what my results are.
I will need to get the parts for the bottom end. (Water in lower end gear/oil). What is the best practice and what additional parts are recommended to replace while fixing the seals? (water pump etc.) Any tips will be much appreciated on what to watch for while splitting this casing and removing parts. Thank you.
lindy46
There is a stop which prevents over-revving the motor in neutral.
