Johnson 1960 V4SL-12 Cooling?
GTP091
I bought a V4SL-12 and the old guy I bought it off had the leg off of it, said it was to much for him to tinker with anymore. I went ahead and bought all the parts to rebuild the leg and new impeller and seals etc. Was very careful with reinstall and lubing the water tubes and getting everything just right. It's pretty simple so can't see how i could have messed it up. Tried to start it today and gladly it fired right up just need to adjust the idle mixture a bit. I noticed it was not pushing water out the exhaust hole on the back of the motor and it heated up fairly quickly so im thinking it may not have water flowing through it?. My little 18 hp johnson has a thermostat and only starts to send out water after that opens. Gets hot but I know it's cooling. I shut it off when the head was to hot to to touch so surely did not damage anything by overheating. Am i being paranoid and all is well or should water be coming out the exhaust port right away? is there an easy way to test water is flowing by removing a hose on the power head?? Im used to the merc pee hole so not sure what to look for on this motor. thanks for the replies!
Chris1956
Honorary Supreme Mariner
OK, so you have a Johnny V4. That motor will spit water out the back of the midsection, after the thermostat opens. It will only spit, under normal conditions. Most of the water exits from the gearcase area.
Do you have it running in a barrel of water? That is the only way, and the water level must be above the water pump, by a bit. You might open the thermostat box and see if the thermostat is working. You can leave the thermostat out for a test. The water jacket is supposed to be pressurized by the spring and plastic plug. Water is supposed to recirculate until the thermostat opens, hence the two water tubes on the pump.
F_R
It should blow some water out the back, regardless of thermostat position. But more when it opens.
BTW, an 18 should discharge water regardless of thermostat position also. In both cases, that is necessary to cool the exhaust at all times.
GTP091
Thanks for posting. It's immersed in water past the water intakes so no issues there. I checked out the thermostat housing on marineengine.com so have a better understanding of how it all works now. i did not know the motor exhausted out the prop until i started it and now you say cooling water comes out there as well. I will take the cover off the thermostat housing and check it out and go from there. will post my findings.
GTP091
I took the cover off the thermostat housing and it was bone dry so definately not getting water, I hooked my water hose up to the inlet/outlet on the head and opened up the other side. when started the heads stayed nice and warm. so luckily i didnt run it to long with out being cooled the first time. hope i didnt bugger something up. with such a short run. Now im not sure why it wouldnt be pumping. is there a way to attach earmuffs to this motor?? my water tank also did not come up completely to over top the water pump so maybe that's where the problem lies. I will get a garbage can maybe and try that.
Chris1956
Yes, the flush water in the garbage can must be above the waterpump. The water inlet is that small screen behind the prop, and the screen on the gearcase, above the A-V plate. A conventional flusher will not work well, if at all. Use a barrel for your testing.
GTP091
Well i hope thats it then. I had the screens covered for sure but maybe not up to the pump but almost there. I've seen several videos of this motor on you tube that had the water line where mine was or below it even and they were pumping just fine but who knows. Off to the hardware store to get a taller can!
GTP091
Does anybody know if any of the water lines can be tapped into safely to provide a tell take pee joke I could put out the back on this motor? All is working well just hard to keep an eye on it when driving the boat. I know there's a fix for the smaller Johnson motors by tapping into the thermostat housing. I just don't want to tie into the cold side. If I had a diagram of the water routing that would be awesome
F_R
Seems like everybody these days has to watch their motor pee. The blow hole out the back should be plenty for anybody. Nevertheless---------------
If you think you just gotta have a tell tale, there is a water hose running from the starboard side of the powerhead to the automatic choke. Remove the elbow from the powerhead and rig up a T fitting. Restrict one leg of the T down to a skinny squirt (tell tale).
GTP091
thanks that should do the trick. It's just nice to be able to see the motor cooling from the drivers seat and not have to constantly think about if its cooling properly when you cant see it. Now that I finally bot my new old boat home I need to get it rigger up.
Tell tales were not installed back then because there was no need for them.---Water spitting out the exhaust relief is good enuff.----If you install a new impeller every 3 years you do not need a tell tale pisser !!
Chris1956
A lot of the 60's Big Twin engines had overheat alarms. I don't think they installed them in the V4 motors, at least not on my Fat-Fifty.
The 1961 model 75 hp shows the temperature warning switch in the cylinderhead.
