Johnson 1955 5.5 Prop Question
shipwreck
The Prop Spins ( Squeaks) Around The Rubber Hub Inside when force is applied,
it is slipping.
I Have Removed It And Cleaned The Rubber And Roughed Up Inside Of The Prop where the rubber hub was seated into.
Do I Apply Any Glue For Lack Of Better Word, Or Just Pound Back In?
steelespike
Re: Johnson 1955 5.5 Prop Question
You need to take it to a prop shop and have the hub properly installed or
or have a new hub installed
shipwreck
That is not very do your self in the style ......i- boats.
JCF350
That is because this is not a do it yourself type job. You must have the correct equipment to reinstall the hub in the prop with a NEW rubber.
steelespike
What he said, Had a friend years ago tried to fix a 14 hp Scott prop.
Three times finally somehow rigged a bolt to hold it together worked for awhile but shook terrible and if he hit something it would most likely have messed up his gear case.Fortunately he found a prop before the vibration ruined his motor.
