freddyray21
- Jun 10, 2006
- 2,460
Re: Johnson 15hp 2-stroke high pitched noise then stopped working
there is no gasket between the crankcase halves. Never was one. Just use the proper sealer when you put it back together. I think perhaps you may have broken a rod or rod bearings and that is why it hung up when turning. It would also explain the slop in the one piston. You will find out when you get the halve separated.
