johnson 155 cant get it to high speeds!!
BEKO1212
i have a 1984 johnson 155 model J155WTLCRS.when i got it out of water throttle opens up no problem.when i get it in water sometimes it will but most of the time when i push full throttle i barely goes.and also when warmed up it stalls sometimes when i put it in gear.not sure if its fuel or spark problem.i took the motor cover off at night once and one of the coil packs u could see little sparks coming out of it.
BEKO1212
Re: johnson 155 cant get it to high speeds!!
today the boat in the water and when i hit the throttle it would stall.when its out of the water it revs up fine.some one told me it could be the primer bulb.
