Gent's I have a few questions for you on a 150 v6 1980 J150TLCSR 1) inter exhaust cover gasket ? the parts list shows 2 gaskets of the same kind are required item # 39 on the diag part # 0321182 I have never seen anyone use a double gasket on anything is this right I have to double the gasket??? 2) do I need any gasket sealant on these? if so which is the best ?? 3) does anyone have the torque specs and bolt pattern for the exhaust cover there are about 26 bolts on the 150 175 and 200hp. thanks I did the search and did not find anything about double gaskets or sealant
