Johnson 150hp 1980 exhaust cover
hranec
Gent's I have a few questions for you on a 150 v6 1980 J150TLCSR 1) inter exhaust cover gasket ? the parts list shows 2 gaskets of the same kind are required item # 39 on the diag part # 0321182 I have never seen anyone use a double gasket on anything is this right I have to double the gasket??? 2) do I need any gasket sealant on these? if so which is the best ?? 3) does anyone have the torque specs and bolt pattern for the exhaust cover there are about 26 bolts on the 150 175 and 200hp. thanks I did the search and did not find anything about double gaskets or sealant
Joe Reeves
Two gaskets........ One gasket on each side of the inner exhaust baffle plate. Not a double gasket.
hranec
Sir, I understand what you are saying BUT the parts list on this sight said that part number #39 requires 2 gaskets. this goes on the inner exhaust baffle plate to the block, then gasket # 34 goes from the inner baffle plate to the exhaust cover. I agree one gasket should be on one side and another gasket on the other side. These are two different shaped gaskets to that I agree yet the parts list said two #39's are required. Not trying to be a pain in the butt I'm just going by the parts list. I've got no problem doing the 1 gasket on each side just want to do it the right way. Can you offer any help on the gasket sealant , torque spec and bolt pattern on the exhaust cover????? Thanks
V153
No double gasket. (Misprint mebbe?) One gasket between the engine block and filler. One gasket between the filler and cover. Use Permatex Aviation Form-A-Gasket sealer from Napa. Part # 765-1210. Unless you have deep pockets and insist on using the OMC stuff. Torque to 60-84 in. lbs.
Joe Reeves
I just checked the OMC parts book for your engine and see why you are so confused..... Part #34 pertains to a 235hp model as does the related parts in the graphic.Part #39 states two (2) gaskets are needed for the 150hp model.
Trust me... The book can be quite confusing to someone that doesn't work on the engine every day as that one page is describing parts/gaskets for three different horsepower models... the 150, 175, and the 235hp.
Your 1980 150hp used two (2) exhaust baffle plate gaskets, part # 321182 . I guarantee it.
hranec
thanks very much, I'm sure I'll have more questions later
