JOHNSON 150 NOT FIRING ON ONE CYLINDER
Status
Not open for further replies.
WRIGHTWARREN
I have a 1990 Johnson 150 GT.It was not getting fire to #2 cylinder.I replaced all the coils and still no fire to #2.Compression is 95 on all 6 cylinders.I installed a new power pack(guy at marina said thats what i needed) and still no fire on #2.I installed new trigger and stator and still no fire to #2.Im over $800 in parts alone and cannot get spark to #2.Any suggestions or Ideas that I may try? I am stumped by this one and dont want to put any more money in it and still have the same problem.PLEASE HELP
emdsapmgr
You've pretty much replaced all of the normal ignition components on the engine. You'd think one of those parts would have been at fault. So you are down to the really unusual potential problems-seldom seen on these engines. I'm wondering if you have a flywheel timing ring problem.
WRIGHTWARREN
flywheel looks okay and the magnets are good.any way of checking it or anything to look for other than the magnets?
Honorary Supreme Mariner
Carburetor clean for that cylinder ?---Reed valves checked ?
WRIGHTWARREN
I can switch #2 orange wire from powerpack with number #4 orange wire from power pack and #2 will fire but #4 wont.So im guessing it is not firing out of powerpack on #2 orange wire.Powerpack,trigger and stator are brand new but still no fire to #2.I did not have fire to #2 prior to the new parts either.What else controls spark that could cause this? Ive checked all connections,grounds and everthing is okay.Flywheel is good....scratching my head.
1983 ercoa 21'
Before checking timer base. Trade power packs from one side to the other. Remember orange blue wire top coil
orange in the center
orange green on bottom.
see if the problem moves with pack if so your new pack is bad.
WRIGHTWARREN
im going to check timer base with dva and see if its bad even though its new.this motor only has one power pack.i will update after i test timer base.
Fed
When you say 'no fire to #2' do you mean #2 is getting no spark or #2 isn't doing anything?
IE, checked with a spark tester or checked by cylinder drop test?
gm280
Amazing to hear that you initially had #2 not firing and then you replace all the components and still have no fire on that same #2 cylinder. The odds are nearly impossible. I mean IF you verify a bad NEW pack, something took out the number 2 firing capability. I can't see a new pack having the exact same problem as the old one. So maybe something is taking it out if the pack is determined bad now... JMHO!
GA_Boater
And the OP hasn't been seen in years. One of the reasons we ask the old thread are left undisturbed and treated like a library book.
Closed.
Status
