BigBassin78
Thread starter- Joined
- Aug 13, 2011
- 64
Re: Johnson 150 Fast Strike rev limiting @3000 (video link!)! New boat please help!!
i did not disconnect it but just to test for the alarm. I hooked it back up, and when I ran the motor it went into slow mode immediately. Neither of the temp switches were making the alarm sound. I disconnected both one at a time and alarm continued to sound. Anyway, I am still trying to figure out why it is going into SLOW. I am hoping that when I resolve the VRO sensor thing that this will also fix the SLOW thing.
BTW according to my SELOC, SLOW stands for Speed Limiting Operation Warning.
PS: this is something I learned yesterday that I want to share in case this happens to someone else. Once I got the new starter on and the motor running I could not get it to idle, it would only continue to run with the throttle advanced. After about 2 minutes of this, trying to get the motor to idle, I went over the motor and noticed that there was a copious amount of oil sprayed out of the exhaust in a 12 foot streak and dripping from the prop. I thought this was bad, so, remembering that I had turned the little red lever from where it was and could not remember its original position, I thought I should look into this first. So, I turned it to 6 oclock position and it returned to normal operation and idled just fine. But again would not go passed 2500 rpm... Saga continues..lol
