I would appreciate inputs. I have this old Johnson commercial version that was overheating due to a blown head gasket. I removed the head, clean passages, replace gaskets, put it together again. Also replaced thermostat and water pump. Yesterday I tested it at home with muffs and after about ten minutes it starting running hot, or at least what I think is hot. At the thermostat housing I was reading +-150F and at the head near spark plugs around 210F. I can tell the thermostat opens because the water out of the exhaust gets warmer and the temp stabilizes.It pees strong and there is water out of the exhaust. Isn't this too hot for an outboard? might it get cooler in the water at higher RPM?
Thanks!
Thanks!
