Bob in Calif.
Thread starter- Joined
- Nov 4, 2002
- 653
Johnson 100 hp Commerical opinions???
A while back I replaced my '78 85 hp Johnson with a '87 Johnson 100hp commerical engine. The 85 hp didn't have tilt and trim, but the 100 hp. does. <br /><br />I am using it on an 18' Campion Cuddy Cabin, which weigh's about 1/4 to 1/3 more than a similar Bayliner. It use to top out at about 32 or 33 mph. <br /> With the new engine, I was getting apx. 40 mph, and only reaching 4800 rpm's. I found an electrical problem, which corrected my igntion problem. I went thru the carbs and it runs real sweet. It came with a new VRO on it and it works fine.<br /><br />It came with a 15X19 stainless prop, which I have replaced with a 15X17 aluiminum cupped prop. I expect it will reach 5300 rpm's now and get close to 45 mph. Due to whather conditions, I haven't been able to try it out since.<br /><br />Does anybody have any opinions pro or con regarding the 100 hp commerical.<br /><br />Before you ask, yes I replaced the water pump, thermostats, etc. and naturally I have the OMC shop manual for it
<br /><br />I worked for a OMC dealer/repair shop several years ago, But during the time I was there, untill the time the owner retired, we never had one of these come in for anything. I take that as a good sign.<br /><br />The best part of it is, I got the engine from another dealer, a couple cities away, who acquired it as a trade in. I got it for only $500.00, stainless steel prop, in good shape, included!!<br /> <br /> ...Bob in Calif
