Johnson 100 hp Commerical opinions???
Bob in Calif.
A while back I replaced my '78 85 hp Johnson with a '87 Johnson 100hp commerical engine. The 85 hp didn't have tilt and trim, but the 100 hp. does. <br /><br />I am using it on an 18' Campion Cuddy Cabin, which weigh's about 1/4 to 1/3 more than a similar Bayliner. It use to top out at about 32 or 33 mph. <br /> With the new engine, I was getting apx. 40 mph, and only reaching 4800 rpm's. I found an electrical problem, which corrected my igntion problem. I went thru the carbs and it runs real sweet. It came with a new VRO on it and it works fine.<br /><br />It came with a 15X19 stainless prop, which I have replaced with a 15X17 aluiminum cupped prop. I expect it will reach 5300 rpm's now and get close to 45 mph. Due to whather conditions, I haven't been able to try it out since.<br /><br />Does anybody have any opinions pro or con regarding the 100 hp commerical.<br /><br />Before you ask, yes I replaced the water pump, thermostats, etc. and naturally I have the OMC shop manual for it :D <br /><br />I worked for a OMC dealer/repair shop several years ago, But during the time I was there, untill the time the owner retired, we never had one of these come in for anything. I take that as a good sign.<br /><br />The best part of it is, I got the engine from another dealer, a couple cities away, who acquired it as a trade in. I got it for only $500.00, stainless steel prop, in good shape, included!!<br /> <br /> ...Bob in Calif
D
DJ
Guest
Re: Johnson 100 hp Commerical opinions???
Bob,<br /><br />You got a sweetheart deal.<br /><br />The "commercial" is simply a V-4 crossflow powerhead sitting on top of a V-6 gearcase.<br /><br />It think I would prop it to turn a few more RPM's though. Perhaps a 15". You wouldn't have to run it WOT all the time but it would give you a bit better holeshot and lower speeds at which you can stay on plane.
Bob in Calif.
I haven't been able to try the engine out since I corrected the electrical problem and insalled the 15 X 17 cupped aluminum prop, so the RPM range and top speed are estamate's, but I don't think I'm too far off. <br /><br />With the 15 X 19 SS prop,the boat actually planed in about 3 seconds, 4 seconds at the most, with two people aboard. That was a very nice feeling compaired to the old engine, which would take 5 or 6 seconds.<br /><br />With recent winds up to 30 mph on San Francisco Bay and more storm's comming in, it will be a while untill I can take it out for another test. That is if I can get it out of my pasture area with my buddy's 4 X 4. It's getting a little mushy out there. :confused: <br /><br /> ...Bob in Calif...
