Jetting a 20 HP Mercury
TTG
Hi there, I have a 2001 20 HP Mercury that I would like to jet to a 25.
The 20 and 25 have the same cubic inches, bore and stroke, lower end, ect.
After researching parts lists on the two , I found I would need to order a bigger jet , a "valve throttle" (that sits between the carb and the head ) and some gaskets.
These are the only parts that seem to differ from the 20 to the 25.
I would like to get the extra 500 RPM .........Has anyone done this? Are there any other parts that I would need?
Great Site! ......George
Laddies
Banned
Re: Jetting a 20 HP Mercury
The jet will not help without the tune pipe it will just use more fuel.
TTG
Were is the tune pipe located? Is this something I can change?
Laddies
Banned
It's the tube right below the powerhead on the driveshaft housing adapter plate
TTG
Hey , thanks for the info, now its a matter of finding one I tried Crowley Marine, any oyther good sites for looking up those type of parts?
8075mercury
One thing I would double check is the intake and exhaust port size. I know you can not do the swap you describe on a 7.5 and 9.8 because not only is the carb different, but the intake and exhaust ports are smaller on the 7.5 than the 9.8. I thought, no problem, just drill them out, but the centerpoint is different too. So, my 7.5 stayed a 7.5.
I would bet that the 18/25 and 20/25 is the same situation. At least I would check by opening the intake and exhaust covers before getting all of the conversion parts.
Good luck!
8075mercury
Well that is good news if that is the case because you could do a hp increase pretty easy.
Good to know.
Thanks!
Laddies
Banned
8075, the problem is that Mercury has made those items about as scarce as hen's teeth, so you would have to find a older 25 for a donor engine.
TTG
Yep, I cant find hens teeth anywhere!!
25xs
Yes, the jet is all you need... Tuner pipe is same from 15hp thru 25hp
You can easily make your 20 into a 25 by rejetting and letting the max timing advance travel as far as possible... You pretty much can not "over time" this engine.
rtse66
wow, if i'd seen this i wouldn't have posted my question. i assume this will also apply to an 84 18hp? sounds like what 24xs said is that all you have to do is change a jet and adjust the timing stop. i'm a newbie when it comes to outboards so anything will help. sorry didn't mean to hijack the thread but i'm in the same "boat" . rob.
25xs
20hp & 25hp tuner pipes are the SAME in 2001 Rejet the 20hp to make a 25hp
Part No. 99702A7 is the tuner plate adapter which includes the exhaust tuner pipe... It's the same between the 15XD/15SeaPro/20hp/25hp motors in 2001 and surrounding model years. You can make a 25hp motor from a 20hp pretty easily.
