Jackplate--good or bad?
Paul2375
Hi everyone,
So finally got the transom repaired on my 1976 Sea Ray 195, just gotta paint it. I have a friend who made a few jackplates, and swears by it. My question is, does it place more strain on the transom? My motor is tall so the theory behind it sounds good, but I'm not sure...would really appreciate some advice/input.
ondarvr
They aren't good or bad, if they can work in your situation and help make the boat more enjoyable for you to use, It would be considered good. If it was just a hassle and expense to install that served no useful purpose it wouldn't be so good.
Not sure what you mean by "my motor is tall".
It will put some extra stress on the transom, but if you did a good job in fixing it the extra load shouldn't make a difference.
Paul2375
I was just looking at it this week and figured less drilling through the transom would better. I guess I meant it's a long shaft motor, 1977 V4 140 Johnson outboard. Wasn't sure if I could use either 2" or 3" angle iron.
What do you intend to use the angle iron for?
Most powered jack plates are either aluminum or stainless. If made from angle, usually 4" leg, 1/2" thick or thicker
Paul2375
I was going for a fixed height with my idea, I was going to use the 1/2" angle iron for the construction of it.
Paul2375
Lowes has 1/2" angle iron, but only light aluminum. Would 1/2" aluminum be a better choice? I guess it would be lighter
buy metal from your local metal supply shop. lowes carries really low quality structural shapes at a really high price.
the thickness depends on what you are building and how its designed.
Paul2375
Good to know, I'll definitely look that up and find some aluminum angle iron
ondarvr
Your boat should use a long shaft motor, so most likely you can get it in the correct height range without a jack plate. Still not sure what your goal is, or what type of Jack plate you plan to make.
Frey0357
Hello Paul. Perhaps some photos of your boat set up and your goals for installing a Jack Plate might help us to help you.
I installed one on my 14' aluminum boat, and it turned out fantastic! I made it myself with 1/2" aluminum angle 2x3". Mine was smaller since it was only for a 25hp motor.
Frey
Paul2375
Thanks for the info. I will try and get some pictures this weekend. I am trying to avoid drilling into the new transom as much as possible. I need to find out what thickness I need to support the motor weight...which I believe is around 300 pounds.
