Jack plate to use 25" motor
CMur
I am looking at a used 90 hp four stroke for my boat but it is a 25" shaft and my boat has a 21" transom. Can I put on a manual jack plate to convert the transom to use the 25" shaft?
Also will this setup overly stress the transom?
BWR1953
Re: Jack plate to use 25" motor
Yes, you can do that. However, jackplates often cost several hundreds of dollars. Might be worth it to keep looking around and find a 20" shaft motor.
