J50tleod wont idle
kax2000
1st Post-1st Boat-1st Day on the water was yesterday.
1995 50hp Johnson (on a '87 Ebbtide Dyna Trak 166 STE) won't idle.
Have to use the neutral throttle lever to keep it running.
Bogs and low power 1st 1/2 of throttle up..then revs high with lots of power between 1/2 and WOT.
Starts everytime no issues.
Any help would be appreciated.
Haffiman
Re: J50tleod wont idle
First information needed is a compression test.
Next, do you have strong spark on both cylinders?
kax2000
Compression test result = 125 for both cylinders and strong spark on both.
Haffiman
Give the carbs a good clean. Use a spray can with carb cleaner and be sure low and intermediate channels are clean and clear. Replace at least all gaskets.
kax2000
Checked the fuel in the tank. It looks cloudy.
Could moisture, old gas or fuel additive cause the cloudiness?
Either way i will swap for some fresh stuff before i use the carb cleaner.
kax2000
So can moisture in the gas make the motor run poorly at an idle but at higher rpm run fine?
