I bought a used non running johnson 150 v6, was told up front that it over heated and was towed in 3 years ago and has been sitting till I came along. Anyway I have replaced the water pump, drained and refilled the lower unit, rebuild the carbs, compression runs 107 to 117, I am now starting on the thermostats. BUT when I removed the thermostat covers I found what I'll call the (pressure valve) located just lower of the thermostats to be dry,crack and broken. So now I will start getting those parts together. Part # 86, 87, 88, 89, 95 and a few more. The QUESTION is part #89 WASHER,VALVE it sits inside of the cylinder head cover #24 and looks to be a tight fit maybe even pressed in. Is there any special way for part #89 to be removed and a new one installed???? I really do not want to break the head cover trying to get the old one out and the new one in. The book does not say anything except take it out and replace it.
THANKS for any and all help.
