Isbn # for service manual
sunchaser81
Hello,
I am going to order a factory service manual for my motor and I was wondering if someone could give me the isbn # off the back of there manual. The manual I need is for a Evinrude 90hp vro 1989 or 1990 (no id plate) I am trying to find out if this manual will cover the two years on this motor and i want to make surre I get the right manual
Thanks for your help
Sunchaser81
dajohnson53
Re: Isbn # for service manual
You should just go to kencook.com and order the manual for your engine. They are the source for original manuals for older OMC's, in your vintage. There are other sources, but they get them from Ken Cook. At that site, and the other sites I've seen that cary OEM manuals, you won't order by ISBN, but by the actual model number of your engine.
I have this bad feeling you'll need to know if it's an 89 or 90. I think my 1990 manual only covers that year.
If you want a Seloc manual, this site carries them, they might be more generic where you can get away with a range of years when ordering.
sunchaser81
thanks for replying dajohnson53
I have seen the sites that I would order a manual from and your right I need to find out the year of my motor. I have posted earlier with pictures and info of the motor so someone could help me pin point the year. the title of the post is
Trying to find out model # w/out plate on transom bracket.
The reason I need the isbn # is if they are the same for 1989 manual and 1990 manual then they would be the same book but with a different order # from where I order it from.
I have a Selco manual and in my opinion it is to general.
I would like to have the right manual for this motor as I may have to do a rebuild because of a blown ring in # 3 hole, but I will post that stuff later when I go to do that.
Thank you for your help
tashasdaddy
i looked at outboardbooks.com / kencook.com the OEM numbers don't match for 89 and 90 models, don't know the praticular difference.
