Is there a part number for 1960 piston rings
justinlea01
I need piston rings for my 1960 25hp sea king. Ive been searching the web endlessly, but none of the omc or sierra parts go as far back as 1960. Please help
F_R
Honorary Supreme Mariner
Re: Is there a part number for 1960 piston rings
No problem. Original part number was 302533 which was for individual rings. New number is 378421 which is a set of 3 for one piston. Get them from an Evinrude dealer. Sierra doesn't have them.
justinlea01
Thanks Admiral ..
I ordered the rings and already broke one. what is the trick for getting these bastards on the piston?
ohm116
Piston ring install tool to open them up and slide them on to the piston and a piston ring compressor to squish them down so you can slide the piston into the cylinder. You probably already know that though.
justinlea01
Hooray I got those little devils on. I didn't use the tools. Instead of trying to pull the ring apart I slid it over the bottom of the piston then pulled the ring apart. Anyway thanks for all the he replies. Tight lines.
