Onebadpolaris
Thread starter- Joined
- Mar 13, 2009
- 4
I just bought a Sierra foam transom seal for my 89 OMC cobra and the old one was a rubber one with no break in it. This new one is a foam one that will have to have a joint in it which seems dumb because it just a rope foam seal. how are you supposed to seal that joint up correctly and is there a silicone or sealant of some type you use around the whole seal? Or should I find the oem rubber one? I have a OMC manual and it says to use "OMC adhesive M" is that the same thing as like permatex ultra black? Thanks, Austin
